wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-11T11:33:08+00:00
    similar problem here.  connections go limited very frequently.  I am able to reset wifi by htting airplane mode though.
    This happens most often when I move from on location in the house to another. I'll hit the button, close the touch cover, and move. There is usually a few minutes that pass before I get back on. The is with the ARM version of Surface.
