wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-11T10:29:43+00:00
    thanks,
    switching off 802.11n worked perfectly.
    This is the only thing that worked for me however I refuse to be stuck with 54Mpbs speeds on my entire wireless network because I own a surface.  This should work with 300Mbps or higher speeds.
