wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-11T08:02:03+00:00
    For me, I fixed the problem by changing the AutoUse40mhz to 0 in registry only. I leave my router wifi b/g/n mode in Auto, Band in Auto, set it to use 20mhz only, wifi security in WPA2 Personal with AES. I am using Buffalo router. Looking forward to tomorrow's patch. If the patches don't work, I have no words to say.
