wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-10T12:41:45+00:00
    I posted my concerns about lack, of response in this thread:  http://answers.microsoft.com/en-us/feedback/forum/mods/wifi-issues-thread-is-not-getting-updating-by/f33a5527-e128-4cdd-be26-73ec382f0fe6
    If we don't have a working fix this patch Tuesday I am calling MS one last time and giving them a chance to take this paperweight back otherwise I am issuing a chargeback on my credit card since I am passed my return period.  I foolishly gave MS the benefit of the doubt and allowed them to release a fix which never came...
