wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-10T12:07:59+00:00
    It would be nice of Microsoft would monitor these discussions and confirm what they are doing to fix this.  It is a fault 100%; I never have the problem with my other laptop and I'm on different networks every week with each pc.  It IS a surface problem.
