wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-10T02:32:33+00:00
    for now your only recourse is to
    a) downgrade all your N routers to G and see if that helps
    b) buy something like this: AirLink101 AWLL5088 Wireless N 150 Ultra Mini USB Adapter (search for it on Amazon)
    I chose option b and it looks like we will be stuck with it a good long while.  I tried the built-in wifi after the latest patch tuesday and the problem continues to persist...microsoft support will only say "we're working on a fix, no ETA", and since the problem has existed since Oct 2012...well you can see where this is going
    I am telling everyone considering buying a Surface that 802.11n is totally unreliable with this device and to decide accordingly
    also beware of people in this thread who say it is fixed, the problem is related to throughput on the nic, so it is possible to get 1-3 days of light web browsing before the problem resurfaces...I have yet to see anyone who has pushed a couple of gigs through an N router and not seen the problem hit the Surface
    microsoft has not even pushed any networking or driver updates so it makes utterly no sense to say that a recent update has fixed it, but many people don't know how to troubleshoot and leap to conclusions prematurely
    I am by no means defending the Surface, the WiFi problem or claiming there is a general fix, but this is not true regarding low-bandwidth-only scenarios. My case may be the exception, but I have piped several GBs through my Surface WiFi over the last month without issue.  I had the same limited connectivity issue between early Jan and the last few days of Jan, after receiving it for Christmas. I am not someone who does not know how to troubleshoot, either. After every update or change made, I ran the same gamut of tests or scenarios and did so repeatedly for at least a few days before posting or suggesting anything was fixed.
    Since the last week of Jan,  my Surface began working with the three 11n routers or APs I deal with, and that was not the case between Jan 7 and Jan 26.  Since then, I can move between APs without any limited connectivity issues, without restarts, allowing it to sleep in between, etc.  I have no idea what the problem was, all I can say is it stopped happening and it's returned to normal. For all I know it will rear it's ugly head again at some random point in the future. For the last six weeks though, it's been gold. I have streamed HD content from other computers; I have transferred multiple and single files over 2GB to and fro; I have hopped between AP's operating on different frequencies (20 or 40 ghz), and hopped between with varying time intervals ranging from a few minutes to hours to days. I've done so after standby, while 'live' the whole time, and even from cold starts after letting the batter run out.
    Do not presume anyone reporting their unit behaving normally is jumping to conclusions.
