wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-09T21:00:00+00:00
    also beware of people in this thread who say it is fixed, the problem is related to throughput on the nic, so it is possible to get 1-3 days of light web browsing before the problem resurfaces...I have yet to see anyone who has pushed a couple of gigs through an N router and not seen the problem hit the Surface
    We haven't met, but I routinely push a couple of gigs through my N router (two of them) from my surface RT without having any problems: I have some powershell scripts written that move folders full of camera RAW files to my NAS, and I've never had the limited connectivity problem under those circumstances. Those folders are always 2,3,5,7 gigs worth of stuff.
    Of course, that doesn't mean I haven't had the limited connectivity problem. I get it intermittently, sometimes not for weeks, sometimes several times a day. Disconnecting then reconnecting the connection always fixes it for me, luckily. It's still annoying, but hardly a deal breaker for me.
    I've used my surface RT in airport and hotel hotspots many times to stream netflix and hulu and very rarely had a problem with dropping connectivity. Those are likely G connections, I suppose.
    (I got some more frequent drops the first week with the thing on my home N network, but they pushed out many patches after that, and something seems to have changed, because that behavior is long gone.)
    Others may have other experiences.
