wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-09T20:34:42+00:00
    I have all of the problems described in thsi thread connecting to my home N router and many other N routers.  limited connectivty or just can't connect at all.  This is very frustrated.  What are my options here?  none of the workarounds have worked.  i have tried disabled ipv6 and the registry workarounds with no luck.  When are we getting a fix?
    Given that the problem now persists for month, I recommend opening an own support call on surface.com to emphasise the urgency of the problem. Microsoft is either not aware of how widespread the issue is or they have no clue how to fix it and need to assign more resources to it.
