wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-09T19:44:54+00:00
    for now your only recourse is to
    a) downgrade all your N routers to G and see if that helps
    b) buy something like this: AirLink101 AWLL5088 Wireless N 150 Ultra Mini USB Adapter (search for it on Amazon)
    I chose option b and it looks like we will be stuck with it a good long while.  I tried the built-in wifi after the latest patch tuesday and the problem continues to persist...microsoft support will only say "we're working on a fix, no ETA", and since the problem has existed since Oct 2012...well you can see where this is going
    I am telling everyone considering buying a Surface that 802.11n is totally unreliable with this device and to decide accordingly
    also beware of people in this thread who say it is fixed, the problem is related to throughput on the nic, so it is possible to get 1-3 days of light web browsing before the problem resurfaces...I have yet to see anyone who has pushed a couple of gigs through an N router and not seen the problem hit the Surface
    microsoft has not even pushed any networking or driver updates so it makes utterly no sense to say that a recent update has fixed it, but many people don't know how to troubleshoot and leap to conclusions prematurely
