wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-09T01:15:44+00:00
    I have all of the problems described in thsi thread connecting to my home N router and many other N routers.  limited connectivty or just can't connect at all.  This is very frustrated.  What are my options here?  none of the workarounds have worked.  i have tried disabled ipv6 and the registry workarounds with no luck.  When are we getting a fix?
