wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-07T22:32:45+00:00
    Over the past several days I have noticed very frequent (1-2 per hour) loss of connection and/or limited connection at both home and work.  Whatever MS has been doing to try to fix this issue through updates is not working for me and appears to be making things worse.
