wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-07T14:49:28+00:00
    ... but my device magically re-started working reliably about three days ago. I have no clue what caused the change, but I cannot reproduce the behaviour any more.
    Same thing happened with me.  I'm not sure if an update came in while I was at work where the connection was stable, but all of a sudden about three days ago, the limited connection issue went away at home.  I took my Surface from it's bag and it was already connected and it works perfectly now, even in rooms it never could connect in.  I have Comcast and they did some work in the neighborhood to improve the cable service and I thought that might have contributed. Not sure, but it works now.
