wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-05T19:41:53+00:00
    I did open a support call about my Surface Pro. Microsoft sent a replacement which does exactly the same old Limited connection nonsense every few minutes. It worked for a good while tethered to my phone, which uses 802.11g WPA2-PSK, but I'm not about to do that all the time. Enterprise environments all use 802.11n WPA2-Enterprise.
    Interesting - that is exactly the opposite behaviour of what I experienced with my Surface RT. Once our admins had fixed the Cisco issue, it worked perfectly in the WPA2-Enterprise environment while I continuously had Problems connecting to my WPA2-PSK AP at home. This evening, it again connected without any problem to my private WiFi although there was no update, I did not change any configuration on the device nor on the AP. I know that this is not helpful, and I fear that it will come back, but for now the problem just dissapeared without any intervention.
