wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-05T17:00:26+00:00
    My expirience .... Netgear DG834g - Perfect (I've got three of them)
    Netgear DG834n - impossible any connections
    That seems to support the "Marvell theory" - The DG834n seems to use a Marvell radio chip, too.
    My router uses Atheros-based radio chips for both the 2.4 and 5.0 GHz connections, and my Surface RT gets the limited connectivity issue constantly.  My Surface Pro gets the issue a little less frequently, but it still happens there as well.
