wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-05T08:19:52+00:00
    not displaying properly it would be sent straight back or thrown in the bin. Seriously. If the mactards can manage it why in **** can't Microsoft.
    I would recommend opening a support call on the surface.com website as Microsoft does not seem to be aware of the Problem if I understand MSDN Forum User Account's correctly. I was also about to open a call, but my device magically re-started working reliably about three days ago. I have no clue what caused the change, but I cannot reproduce the behaviour any more.
