wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-04T23:28:44+00:00
    Well isn't all great and dandy. How nice for everyone to be able to download updates and restart things and generally creep along with a vague sense of annoyance. I however am the holder of an expensive brick of corporate malfeasance. So.. I can't connect to the WIFI hotspot from the macbook pro here in the office (just happens to be the only laptop here and the only thing capable of broadcasting WIFI from the ADSL2 connection). The connection protocols are the same, everything should work but it doesn't.. I chalk it up to well, being a microsoft/mac issue. I go home and try and plug in my usb modem to install firmware updates. Oh of course I forgot that won't work it's a tablet, it's not like my other windows machines.. Ok ok.. Let's try making my Galaxy S3 a WIFI hotspot.. let's try WPA.. let's try open and unsecured.. limited connection.. turn on airplane mode and off again.. forget connections restart restart restart.. limited limited limited. I don't live near a Starbucks.. these are my connection options. I CANNOT CONNECT TO THE INTERNET. Apparently there isn't even a USB firmware update so It looks like i'm up the creek without a paddle. I'll try the unofficial command prompt fix next but this is seriously BS. If I didn't absolutely need this to test site compatibility as it inexorably takes a few percentage of marketshare and people whine about sites not displaying properly it would be sent straight back or thrown in the bin. Seriously. If the mactards can manage it why in **** can't Microsoft.
