wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-02T22:06:26+00:00
    Well we've had ours a day and was working fine then wouldn't connect to wifi, can't even see anything in network adapter settings. Ironically reporting this on my Ipad that can find the Network with no trouble
