wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-28T03:01:51+00:00
    I have this issue on a Surface Pro.  Mostly occurs in our offices with Cisco Aironet APs but also with my AT&T hotspot.  I can usually disconnect and reconnect which works for a while.  Seems to be worse with bandwidth intensive applications.  Always happens when I am in a GoToMeeting.  It cant occur every 5 minutes, then not happen for an hour.  Have not found a pattern yet.
    At home on Verizon FIOS Actiontec router, I can work all day and never get disconnected.  In the office it is almost unusable.  My co-worker has Surface Pro too in a different office and has the same issues.
