wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-28T01:24:26+00:00
    This issue is acting very similar to to the one I had with my Asus laptop on windows 8 the laptop had the same type of issue and I was able to track it down to the chipset not supporting low power mode, so every time the pc tried to put the chip in reduced power or turn it off the drivers would crash and I would need to either reboot or uninstall and reinstall the drivers.
    I am going to try and disable power saving on the chipset and see if it helps at all
