wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-27T21:07:38+00:00
    I talked to Microsoft support today and they evidently have no clue about this issue.  They setup an rma for it but reading this thread I doubt it will solve anything.
    I have a Surface Pro and symptoms are during any large file transfer the nic goes to "limited" and only a reboot restores connectivity.
    Incidentally, I have seen this problem with a NIC on an Intel board under Windows 2012, so it may well be related to the new OS screwing up the network connectivity.  Just the one NIC, other NICs on the same Intel board have no issues.  I believe it was a Marvell chipset.
    I find it pathetic that the problem is so easy to repro and yet Microsoft support doesn't have a clue about it and no fix is forthcoming.  I don't see how QA could not have detected this problem.  The support guy was a total dick about it too, and tried to tell me my Windows domain was causing the problem.  Yeah right, buddy.
