wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-26T08:18:42+00:00
    I have the same router. Not only am I seeing this issue on my Surface Pro but its also a problem on my wife's iPad and our BluRay player. This isn't a Microsoft problem, it's a D-link problem. I'm about to take it back and get something else. Can't find resolution anywhere on the internet.
    Mine is also a D-link, but I strongly disagree that the problem is only caused by their routers, because my Surface exhibited exactly the same behaviour in my office where we have a Cisco-only infrastructure. I believe that the issue is somehow related to the negotiation of the WiFi security mechanism.
    My expirience .... Netgear DG834g - Perfect (I've got three of them)
    Netgear DG834n - impossible any connections
