wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-24T18:36:47+00:00
    I'm not certain when or how the updated driver came in, but my connection issues seem to have improved dramatically.  I am now able to remote into my desktop with my surface and I don't seem to be losing the connection like I was before.  Hallelujah!
    Mine is now again performing terribly - I don't know why. Takes again about 15 mins to connect. The effect is reproducible.
