wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-19T19:09:04+00:00
    After the latest round of updates, things seem to be better for me.  As stated before, after the Jan 8 update I had all sorts of "limited connectivity" issues with multiple access points and types of hardware.  For about 10 days now I've been able to take my Surface RT between work, home, and at least a couple wifi hotspots with minimal problems.  One one or two (out of 20) attempts to connect one of the office AP's (Cisco 4410N) I got limited connectivity, but otherwise it's been pretty solid.
    The problem has all but cleared up (for the last week or two) on other APs at work or at home; Cisco 1262, Cisco 1131, Cisco 121. In addition, the occasional hotspot at a coffee shop or whatever appear to work ok too.
