wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-19T12:15:16+00:00
    Jumped from a max of 144Mbps to 270Mbps (on 5Ghz) after entering the commands.  DHCP was already set up.  Not sure why you had that command there.
    All good.
