wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-18T05:38:46+00:00
    I am experiencing it in all locations that are not my home network. I have run all the latest updates and it is no better. The disconnect/reconnect solution does not repair it for me, even temporarily.
