wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-16T22:48:01+00:00
    I don't think there's a permanent fix - just wait until MS sort it out. But it's annoying.
    To temporarily fix it, disconnect and then reconnect to your network and it works fine (or at least for me it does!)
