wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-16T00:09:28+00:00
    As of Feb 15, the problem is back so I was able to apply all the latest updates which didn't address the issue.
    If there was an MS store in this country to return the device to, I'd do it at this point.
