wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-14T20:05:14+00:00
    I was a bit hasty wrt. my latest comments as I experienced the same new behaviour after the updates on two consecutive days: the "limited connection issue" now again occurs at my office (it had been resolved after the router update). At the same time, my Surface is faster in connecting to my home WiFi (it usually works after the second try now), which is still not perfect, but at least better than before.
