wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-13T20:24:46+00:00
    So I've just updated the Surface RT with the latest February updates and I still have Wi-Fi connectivity issues.
    This morning I flipped the touch cover, signed in and had to turn off and on the Wi-Fi to get rid of the 'limited' connection status. Is there another update coming. Its a basic function of any computer/tablet/smartphone to connect to the internet. Please fix this!
