wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-13T07:17:28+00:00
    Same experience here.  Firmware update today had no effect on "limited" connectivity issue.  Tried connecting to our 802.11N router, didn't work, just like before.  Had momentary trouble even connecting to our older, 802.11G router, but after a few minutes that rectified itself.
