wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-13T03:44:03+00:00
    Just tested with the latest firmware update, and it doesn't work....
    The Surface is still cannot connect to the 802.11N @ 5GHz Wi-Fi network, no matter WPA2 was set or not.
