wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-13T02:40:41+00:00
    For one brief, shining moment...
    I installed the latest updates, rebooted, and... wonder of wonder, miracle of miracles... (I know, I'm mixing my musicals)... it connected!
    For about 10 minutes. Then the connection dropped, and back to old problems.
    Maybe the March update will work. Maybe.
    The sun will come up, tomorrow...
