wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-13T01:08:02+00:00
    yeah, this update correct the registry tweak we did before, yet failed to fix any wifi issue. i end up reapply the registry fix again as well...
    i am personally on my 3rd surface rt and all of them had wifi limited problem. i guess this issue exist on majority of surface. microsoft really need to get it fixed asap
