wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-12T20:41:53+00:00
    Patches come, but the problem remains. Still need to reapply registry fix to make Wi-Fi work after today updates.
    I have installed the firmware update and all other updates - nothing changed for me, too.
