wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-12T12:42:23+00:00
    Andrew,
    I'm a senior consultant with Microsoft.  While your answer is applicable to the type of problem I am describing, it is not a solution to what I am experiencing.  I have power cycled the network infrastructure here and can still replicate the problem.
    None of the other computers on the network here are experiencing the problems that the surface is.  I've tried Mac OS, WIn 7, and Win 8 with various computers here.  Not able to experience this problem.  Surface, 100% ability to reproduce the problem.
    It's is independent of the router - I've tried 3 here at home and also been able to reproduce the problem at Starbucks on whatever infrastructure they have.
    Final item of note: when this happens, I am unable to turn off the wireless either through airplane mode or turning off the individual wireless item.  Trying this through the command line and a reset that way does not affect the problem.  Only a reboot solves it.  For a while.
    Eric
    May I know which command line you're refering to ?
