wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-07T20:07:08+00:00
    It's still being reported by the media, and Microsoft still has yet to fix it.  C'mon Microsoft, this is getting more than annoying.
    http://news.softpedia.com/news/103-Days-Have-Passed-and-Microsoft-Is-Yet-to-Fix-the-Surface-WiFi-Bug-327074.shtml
