wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-06T19:37:20+00:00
    Today I talked with our netadmin about the WiFi issues. He was on a Cisco user meeting a few days ago and there seem to be various issues with Windows 8/RT devices. Some of his colleagues reported of dozens of RT devices (I am not sure whether WinRT in general or Surface in particular) not being able to connect at all. At least a part of the problems is officially Cisco's fault, because their 802.11w implementation is broken. There is a fix for that, so if you have Cisco infrastructure, you should upgrade the firmware of the Cisco controllers (the release notes specifically mention the Win8 problems).
    However, there are obviously more problems on Microsoft's side, because at home, I have no Cisco hardware and this is the network which is still not working reliably. And as the previous speakers noted Microsoft's handling of the issue is absolutely disastrous. We have a thread with almost 450 posts describing similar issues (and this one is only the largest WiFi-related thread) - I cannot believe that Microsoft has not been able to reproduce the problem and issue at least some kind of statement. I remember some issues with updates breaking Windows Server, and it took them only days to acknowledge this and publish a workaround. As I mentioned repeatedly: my devie worked perfectly when I unpacked it. Some of the updates must have bricked it. I think everyone will agree that Surface is useless without WiFi, so this problem should have top priority for Microsoft. The device is really beautiful and I still like it, so do something, Microsoft!
    In the meantime: Did anyone of you open a support request with Microsoft, and what did they tell? Because I intend to do so as soon as I find the time...
