wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-05T17:24:54+00:00
    DEAR MICROSOFT!
    CLAP CLAP CLAP!
    It has now been well over 3 months and you still have no fix for this issue! You are not a technology company................. You are thieves.
    I work in this industry and taking over 3 months to turnaround a critical bug is unacceptable. All I can say is I'm glad that nobody is buying this rubbish brick of a tablet.
    You fail on the most basic of things,  and your approach to customers is despicable.  I had 4 xbox 360's during the first year due to poor testing and design.  Last week my slim died a death too.
    Bye bye Microsoft, I'm taking my money elsewhere!
