wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-05T04:35:34+00:00
    Holy **** that's exactly what I was thinking! I was complaining about my ultrabook issue experiencing the same problem with Windows 8. Heck, I even posted this complaint in the Windows 8 forum.
    I encountered identical Wifi dropout problem on:
    1. Acer Aspire V5
    2. Thinkpad X1 Carbon
    3. Asus UX31A Ultrabook
    As you can see, all 3 laptops are relatively new. Thinkpad and Asus use the Intel Centrino 6235-N adapter. Acer uses a Qualcomm Atheros AR5BW222 adapter.
    3 different laptop manufacturers, 2 different network chipsets. All 3 with Wifi dropout problems. Now I'm reading that it's happening on Surface too??? Man... I think there's something broken in the Windows 8 network stack or something.
    I've turned off power saving mode on all adapters. I've updated latest drivers on them. No difference.
    I don't even know if Microsoft even realizes this or if even the Support Engineers here even bother to escalate this problem to upper management. Heck, when I was a Support Engineer in the past, I MADE SURE issues like this was reported to the higher-ups.
