wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-29T20:19:13+00:00
    I assume that no one found a solution yet, but I wonder whether we might experience different issues. As I understand, some of you get disconnected after a while. That is not the case for me. My problem is getting a connection at all. If Surface has been able to establish it, it is really stable. Normally, it goes like
    • Network is visible, so detection is no problem.
    • Signal is strong (all bars).
    • I try to connect, Surface says it did not work.
    • I repeat that a dozen times, reset the adapter several times.
    • At some point, Surface gets a "limited connection".
    • From that point, it takes a minute or two until I get a full connection. It somehow feels that if I "just use" the WiFi, e.g. by opening IE, the "limitation" goes away.
    One thing that I can definitely say is that the firmware update in the first week of January made everything much worse for me. Has made anyone the same observation?
