wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-26T18:58:45+00:00
    I think, theres a issue with the low power of the wireless Hardware.
    See my router Log (ASUS RT N65U)
    MAC address : 50:46:XX:XX:XX:XX
    OP Mode  : AP 2,4Ghz
    Phy Mode : 11b/g/n
    Channel  : 6
    Stations List
    MAC                  PSM PhyMode BW  MCS SGI STBC Rate Connect Time
    WindowsPhone7 Yes HTMIX   20M   7 NO  NO    65M 00:07:45
    HPNX8220          NO  HTMIX   40M  15 NO  NO   270M 00:00:26
    WindowsPhone7 Yes HTMIX   20M   7 NO  NO    65M 00:00:20
    OP Mode  : AP 5Ghz
    Phy Mode : 11a/n
    Channel  : 36
    Stations List
    Microsoft Surface RT NO  HTMIX   40M   1 NO  Yes   27M 00:11:41
    All devices position are side by side!
