wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-26T18:24:22+00:00
    I find this issue particularly annoying when trying to use my surface with remote desktop.  I get about 5 mins of work and then it loses the connection.
    I tried the registry hack with autouse40mhz and band.  My surface still connects with N band.
    Is anyone else as amazed as I am at how long it's taking Microsoft to fix this problem?
