wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-25T08:42:17+00:00
    Whilst the Asus EP 121 does not appear to use Marvell technology, the Linksys EA4500 router does use Marvell technology.
    I have checked my router and found out that it also uses a Marvell chip.
    Although the network I originally had problems with is Cisco-only - but as I mentioned I have no Problems here any more after resetting the registry to its original values.
