wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-24T17:29:20+00:00
    I just wanted to jump in here to add my 2 cents and experience.  This is not a surface issue, it is a Windows 8 issue.
    I have a ASUS EP 121 that I installed Win 8 Pro on it.  I also purchased a Surface RT.
    I previously had a Linksys EA3500 and had no issues.  It ran N with no issues on either my surface or my ASUS EP 121.  I have had the EP 121 for 2 years and was running Windows 8 on it from the earliest builds. I never had any issues with wireless connectivity.
    I recently moved to a new house and purchased a Linksys EA4500.  I am having this Limited connectivity issue on both devices.  When it goes to a limited connectivity, I can disconnect and reconnect and problem solved.
    However when I set my wireless to B/G I no longer have the issue.
    So my conclusion is that this is not a Surface issue but a Windows 8 issue since it also effects my EP121.
    I'm catching up on this thread, and was just about to post the same thing. This is problem is NOT limited to the Surface and WinRT. Repeating what I said in a previous post, my laptop running full Windows 8 will connect to my Netgear router, but not to my Verizon hotspot or any other wireless network I've tried.
    Microsoft, if you are looking only at WinRT and the Surface, you are missing the boat.
