wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-24T17:23:11+00:00
    probably related to the driver for the wireless chip. do you know what wireless
    radios are in the afflicted devices? manufacturer and chipset?
    Barb
    MVP - Windows Entertainment and Connected Home
    http://digitalmediaphile.com/
    In reply to Barb and Stoops. Marvell has been mentioned before in this discussion, so I did some quick googling,
    Whilst the Asus EP 121 does not appear to use Marvell technology, the Linksys EA4500 router does use Marvell technology.
    It may be that Marvell technology at either end of a CPU to router link results in major problems particularly with 802.11 N communications.
    Having said that, it is stunning that one of the greatest technology companies of the 20th century still cannot debug and fix a significant problem in a flagship product that may be critical for their future. What on earth are the MS technicians doing ??
