wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
  1. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2013-01-24T16:37:20+00:00
    probably related to the driver for the wireless chip. do you know what wireless
    radios are in the afflicted devices? manufacturer and chipset?
    Barb
    MVP - Windows Entertainment and Connected Home
    http://digitalmediaphile.com/
