wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-24T16:02:55+00:00
    I just wanted to jump in here to add my 2 cents and experience.  This is not a surface issue, it is a Windows 8 issue.
    I have a ASUS EP 121 that I installed Win 8 Pro on it.  I also purchased a Surface RT.
    I previously had a Linksys EA3500 and had no issues.  It ran N with no issues on either my surface or my ASUS EP 121.  I have had the EP 121 for 2 years and was running Windows 8 on it from the earliest builds. I never had any issues with wireless connectivity.
    I recently moved to a new house and purchased a Linksys EA4500.  I am having this Limited connectivity issue on both devices.  When it goes to a limited connectivity, I can disconnect and reconnect and problem solved.
    However when I set my wireless to B/G I no longer have the issue.
    So my conclusion is that this is not a Surface issue but a Windows 8 issue since it also effects my EP121.
