wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-24T12:25:25+00:00
    Hi all,
    just an update on what I tested: I used the "registry hack" in both variations, AutoBand=0 and forcing the band to 4, and AutoBand=0 only (leaving the band 6). In my experience this does not make any difference.
    However, I noticed some other thing: it seems that I can connect to exactly one WiFi network without problems, whereas the other one takes dozens of connect attempts and (relatively) frequently shows the "limited connection" behaviour. Interestingly, the network that is working can change (under conditions I do not understand). So far, I always had problems connecting to the WiFi at my office. That works without any problems since a few days. However, I now have the same problems connecting to my network at home.
    Has anyone made similar experience (with multiple WiFi networks)?
    Best regards,
    Christoph
    Sorry, I did not notice your previous post. I'm able to connect to any network, at least two, without any problems.
