wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-24T11:55:52+00:00
    What is this function "AutoBand" and what they do this parameters?
    There was a post of mr.misterioso in this thread on January 8th explaining this:
    Under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class, you can change "AutoUse40Mhz" and "Band" in order to prevent Windows from automatically negotiating the frequency bands. As I understand that was helpful in some cases, but not in mine.
    Edit: The post is on page 36 right in the middle.
