wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-22T19:07:18+00:00
    My surface has been having the same problems that most people are describing. The problem for me isn't finding networks, but more and more frequently my internet connection gets flagged and says it is "Limited".
    I keep up on my updates and I know basic troubleshooting techniques. Usually, I only have to disconnect my connection from my surface and then just reconnect. After that, my connection gets restored but only for a short while.
    When I first started on the Surface (which was about New Years 2013) I didn't notice any problems. However, the connection disruption started after the first week and now I am resetting the connection every 10 minutes - and that's if I am lucky.
    I have experimented with other troubleshooting techniques, including resetting my router and modem, shutting off all other wireless/internet devices, and restarting my Surface, but nothing makes a difference.
    None of my other devices have spotty internet connection when connected to the wi-fi. So I feel that my Surface shouldn't be having these problems; indicates to me that it is the Surface's problem, not my internet.
    Are there any solutions available yet to fix this? Does Microsoft have the capabilities to fix the problem if I take it in for repair?
    I want to keep using my Surface because it is more convenient to carry around and use than my laptop or relying on my smart phone, but this connection issue is becoming too annoying to put up with. I shouldn't have to be resetting my connection every 10 minutes. It just sets me back on the things I need to get done because I am spending too much time catering to the device's inability to hold a reliable connection; a task that I shouldn't have to be maintaining for it.
